QUICK RELEASE
Old Mar 22, 2007 | 09:16 PM
jdmpassword562's Avatar
Default QUICK RELEASE
hey anyone know how lo install a quick release/ hub adapter???
Old Mar 22, 2007 | 09:44 PM
dohcdelsol's Avatar
Default Re: QUICK RELEASE (jdmpassword562)
simple....
disconnect battery
remove air bag
remove center nut holding wheel on
remove plastic around collumn
run correct wireing for horn and cruise control.
line up slim hub
attach quickrelease hub
attach wheel
thats it in a nut shell but if you search their are more detailed DIY instructions with pictures.
Old Mar 23, 2007 | 07:00 PM
Default Re: QUICK RELEASE (dohcdelsol)
so i cut the air bag to remove the stock steering wheel???/
Old Mar 23, 2007 | 07:01 PM
B18C_EJ8's Avatar
No.
dohcdelsol's Avatar
no
Old Mar 23, 2007 | 07:03 PM
saxqtzk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmpassword562 &raquo;</TD></TR><TR><TD CLASS="quote">so i cut the air bag to remove the stock steering wheel???/</TD></TR></TABLE>
what i did was disconnect the negative terminal of the battery and left it for a good 10 minutes so the juice in the system wouldn't trigger the airbag when I tried to remove it.
Once all the power is out of the system, just disconnect the plugs (yellow in my case) and remove the airbag and the steering wheel. Just make sure you have the proper screwdriver, socket, and steering wheel puller.
Took me about 20 minutes (including the 10 minutes waiting) to do all this. It's very simple.
Old Mar 23, 2007 | 07:12 PM
dohcdelsol's Avatar
Default Re: QUICK RELEASE (saxqtzk)
hardest part is lining up the new aftermarket steering wheel..
no matter how many times i've tried, its never perfectly straight. just gotta go get the wheel aligned at a shop afterwards.
Old Mar 23, 2007 | 07:39 PM
thanks a lot for the help
Old Mar 24, 2007 | 10:46 PM
99SlammedCivic's Avatar
Snipper Snapper
Old Mar 24, 2007 | 11:13 PM
EJ1_Sleeper's Avatar
Default Re: QUICK RELEASE (99SlammedCivic)
Also when you get a chance, pick up a manual for your car. ive got a Haynes and its my bible for all my cars/ friends cars. they help.
Old Mar 24, 2007 | 11:14 PM
bleakdragonmage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol &raquo;</TD></TR><TR><TD CLASS="quote">hardest part is lining up the new aftermarket steering wheel..
no matter how many times i've tried, its never perfectly straight. just gotta go get the wheel aligned at a shop afterwards.</TD></TR></TABLE>
took me 2 tries to get mine to line up perfectly...
Old Mar 24, 2007 | 11:34 PM
ke98248's Avatar
Default Re: QUICK RELEASE (bleakdragonmage)
I have haynes and it pretty much sucks compared to my new book: Helms!
&lt;-- Including the info u need --&gt;
htwitr01
Jul 8, 2010 07:13 PM
DC5mike
Jan 12, 2008 08:15 PM
sushib01
Aug 22, 2004 10:26 PM
UndergroundVR-4
Mar 22, 2003 09:57 AM
the big ragu
Jun 9, 2002 12:01 PM
