Quick Exhaust question: flex section or not?
Old 05-16-2011, 07:36 AM
DSMAddicted's Avatar
Default Quick Exhaust question: flex section or not?
Guys,
I have a WS2 with stock ITR header at the moment.
Between the header and the WS2 catback portion I currently have a high flow cat welded to a pipe (needs to be cleaned up, temporary setup).
I am about to install my RMF Narrow replica header and I would like to clean up the section between the header and the cat-back.
I already have the high flow metal core cat, I need to weld a pipe and flange to it and make it a bolt on piece (so I can swap to test pipe if/when needed).
My question is: Do I buy a flex section and weld it next to the catalytic converter?
Last but not least... which flange do I buy that will mate correctly to the RMF Narrow?
Please let me know your opinion guys.
Thanks,
-Walter
Old 05-16-2011, 08:04 AM
pwebb0207's Avatar
Default Re: Quick Exhaust question: flex section or not?
you need a flex pipe.
Old 05-16-2011, 10:33 AM
H22AFerio's Avatar
you def need a flex pipe. I had that same setup on my coup and kept breaking welds over time. Then I put a piece of flex pipe just after the test pipe and solved the problem.
Old 05-16-2011, 11:09 AM
Awesome, thanks for confirming guys.
Any idea on which flange will work with the RMF Narrow header from this link?
http://vibrantperformance.com/catalo...1022_1122_1153
I guess my question is... does a regular 2-bolt flange (right size) work, or do I need to get a special flange given the special 'donut' looking adapter that came with the header?
Thanks again for confirming,
-Walter
Old 05-17-2011, 07:59 AM
TTT
Old 05-17-2011, 12:20 PM
H22AFerio's Avatar
-Walter
I hacked off the flange that came with my rmf header i dont like the way it bolted up I had too many exahust leaks. so I vouched for a stock style where you slide the donut over the piping itself. if you get what im saying? you can buy the 2 1/2 flange online for like 10- 20 bucks or at a muffler shop good luck!
Old 05-17-2011, 12:22 PM
s13hero's Avatar
Not to thread jack, more to expand on the initial question, would a flex pipe be required for any exhaust setup or just that one specifically?
Old 05-20-2011, 06:06 PM
pwebb0207's Avatar
the engine moves around inside the engine bay. parts that are bolted to the engine need to be able to accommodate for this movement.
Old 05-20-2011, 08:24 PM
NotAJDMFanBoy's Avatar
I didn't have a flex pipe on my truck and it just rattled the exhaust apart. Definitely have either a flex pipe or something.
SLO_EH2
05-11-2010 07:56 PM
19integra94
12-01-2008 05:02 PM
Slow_import
11-17-2008 08:35 AM
toEknEEg
03-07-2004 03:18 PM
GsR HtCh
12-01-2003 06:40 AM
Quick Reply: Quick Exhaust question: flex section or not?
