Quick Axel Question
Quick Axel Question
I was in the process of replacing my rotors and i noticed that the rubber boot right behind my rotor was ripped and leaking thick green stuff... Grease im assuming... Is that something to fix right away? 94 Del Sol S...
Re: Quick Axel Question (98WHP)
you should it will eventually start to cause problems as you loose more grease (lubrication) I had a mechanic forget to clamp down the boot where the axle and tranny meet up and i started to drop bearing and my axel fell out =/
H-T White Ops
Buy a remanufactured set of axles and swap 'em out. Or you might be lucky and not have any dirt/sand/rocks/gunk in your joints yet. Youmight be able to get away with repacking them with some fresh high temp grease after getting some new boots on there. Good luck.
