Questions About my swap
New User
noob first swap need to know what these are and where they get hooked up or do i need to run wires for them
car is 92 bubble
motor is b16a
car is 92 bubble
motor is b16a
Re: Questions About my swap
The green one is the knock senser, and I think the pin type one is the oil temp orsomething? If your not throwing any CEL then your alright. Your stock si/ex (assuming) Doesn't use the knock sensor, but I'm pretty sure it uses the oil sensor. and If your running a p28 or , I think jdm b16 ecu, it doesn't look for the knock.
New User
im running crank position sensor and cylinder sensor the car starts right up and is fine for 2 mins then runs hard like timing is off thought these might of been part of the problem
