Questions about clear corner and tail light bulbs for '95 Civic
New User
I have a '95 Civic EX and was wonderin' if I needed to get new bulbs if I put clear corners in and white tail lights. And if I do, know where I can get the bulbs? Thanks.
Re: Questions about clear corner and tail light bulbs for '95 Civic (e-lauckd)
the bulbs up front are clear... but theyll be crusty white... you could get hyper whites or just go back to orange.. (which you can get at any auto parts store) the tails are also white and any red bulb wont work very well your tail light will be pink and you could possibley get a ticket for that ... you need to find a hyper red... something bright enough to project out... so its as red as it was b4..... check your local performance shop they should carry somethin like that
New User
Re: Questions about clear corner and tail light bulbs for '95 Civic (Inaniac)
Aight thanks. So I don't need a bulb for clear corners, just for the brake light if I get white tail lights? Know where I can go to learn how to install corner lights and tail lights? THanks.
corner lights pop your hood and look where the corner is screwed in its just one screw on each .... unscrew it and pull the old one out.... put the new one on and put the screw back
the tails there are i believe 4 bolts that you just unscrew and remove the light and replace them
i just got harrassed by a cop about hyper white turn signals at nite.....their a distraction....im thinking of goin to orange bulbs sumthing very bright....cause i do get scared during they day making a left turn.....
New User
Re: Questions about clear corner and tail light bulbs for '95 Civic (bommiE)
for the clear tail lights you can use the red led bulbs. you can find them at your local pep boys. just buy the half clear/red tail lights. no bulbs need and no tickets.
e-lauckd
07-19-2001 09:14 PM
