Question on b16a2 intake manifold
i realize on the b16a2 the air sensor is located on the housing of the stock air filter, b18c1's b18b etc... they're located on the manifold itself, now would i have to customize the sensor onto the b16a2 manifold? or is there another way that'll work
Unceasing Measure
Re: Question on b16a2 intake manifold (TurboDOHC-V)
Why would you move it?
I'm going to assume that you didn't tell us that you're turbocharging your car and will be removing the airbox to make room for charge piping. If that's the case, you can drill and tap your intake manifold (take it off first) or you can drill and tap your charge piping (easier to do but more likely to leak). I recommend the manifold.
ultimatehonda
12
06-03-2005 11:24 AM
