Question about my Stock 92 Si
Banned
I'm having trouble with my fuel system. My fuel pump started to intermittently cut off, so assuming my fuel pump was the problem, I replaced my fuel pump. It started right up, so I thought I solved this problem.
Today, I went to go let it run for a bit.. and it seems I just wasted $100 on a fuel pump... as it was not working.
What else do I need to look at? Common issues?
Re: Question about my Stock 92 Si (LSVTEC 91 Civic)
The most common issue would be the main relay. I'd suggest pulling it and checking for any broken solder joints. There used to be a page on repairing them, but it's gone now. If you're handy with a soldering iron, you can fix it. Otherwise, get for for around $50 used.
But main relay is what my money's on.
Banned
Re: Question about my Stock 92 Si (qat727)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qat727 »</TD></TR><TR><TD CLASS="quote">The most common issue would be the main relay. I'd suggest pulling it and checking for any broken solder joints. There used to be a page on repairing them, but it's gone now. If you're handy with a soldering iron, you can fix it. Otherwise, get for for around $50 used.
But main relay is what my money's on. </TD></TR></TABLE>
Cool, Thanks.. I'll check it out.
Something told me too look further before I spent 100 bucks on a fuel pump.. Oh well.
