question about driving style??? answer this!!
a friend and i had a serious debates about whats better for your car....
to stop in second or to shift down to first everytime u stop your car. He shifts all teh way down everytime. I know thats not good for u're tranny, i usually stop in second, the shift down to first, on teh startup when neccessary..
what do you guys do???
Re: question about driving style??? answer this!! (thashadow)
if i know im comming to a stop i just put it in neutral and hit the brakes. (only if i know i have to stop, cause 4th to neutral to 2nd is hell on it)
it might hurt the tranny but thats my habbits.
Re: question about driving style??? answer this!! (EJ_ALbeRT)
i used to put it on neutral and put brakes , but lately i use downshift .. but i never used 1st gear... like 4th ->3rd or sometimes 2nd...
i didn't know it hurts your tranny, i should stop doing it....
There's no need to go all the way down to first. I don't know about your cars, but on my 98 GSR I tried it before and it was one hell of a time trying to get it in first when you're rolling to a stop. Didn't feel too good so I didn't do it. Neutral to brake or 2nd to brake works for me.
Re: question about driving style??? answer this!! (owen_the_soyboy)
Neutral and brakes. Also on my car it is damn hard to get it in first if you're going faster than a few mph.
It's easier to replace brake pads than synchros & piston rings.
[Modified by stocker, 3:12 PM 5/7/2002]
Re: question about driving style??? answer this!! (BoM)
when im slowing..its downshifting all the way down to 2nd when possible...otherwise its to 3rd and in with the clutch to a stop..from the stop..ill usually just work the gears from 3rd to 2nd and into 1st befor starting up again..it didnt seem that compliated when i did it..
Re: question about driving style??? answer this!! (VoltageLS)
i put it into neutral and use my brakes... my friend downshifts all the way to first... and guess what... his tranny is grinding now.
i'm going at 60 mph in 5th gear.
i see the light turn yellow than red.
i press the clutch put it in neutral, and start pressing the brakes.
like said ealier easier to replace brake pads than to put wear and tear on the synchros.
Re: question about driving style??? answer this!! (black2kcivic)
Sometimes I downshift, but it kills gasmileage with a mugen chipped ecu. So lately I have been coasting.
Re: question about driving style??? answer this!! (VTEC)
If you rev-match when downshifting, it shouldn't matter if he goes down to first or second...
i double-clutch down to second, then brake. been doing it for almost 3 years and the tranny is good as new - and so are the brake pads!
Re: question about driving style??? answer this!! (non vtec)
I'm surprised that nobody mentioned what I do: leave it in whatever gear and get off the gas pedal. Press the clutch when the engine is under 700 RPM.
Re: question about driving style??? answer this!! (PupaScoopa)
Re: question about driving style??? answer this!! (CivicEx95)
Exactly what I do. You save gas that way too, because the injectors are turned off when you are not on the throttle and above 1100 RPM. But when you just put it in neutral and brake, then engine is having to use gas to keep the engine idling.
New User
I used to shift nuetral and brake, but went through brake pads pretty quick, stopping from 60 to 0. Steering wheel shakes too when I have to stop from that high at first. Car feels like it likes me to shift to 3rd at about 50 and then just coast and brake if I need too.
[Modified by samdawgsol, 5:17 PM 5/7/2002]
Re: question about driving style??? answer this!! (kf_Type-R)
This is a quote taken from the PGMFI Training Modules that were posted on here a while ago from http://www.tech2tech.net
Coasting fuel shutoff
If the ECM receives a closed throttle input (under.5V), the engine speed is above 1100 RPM, and the engine is warmed, the fuel injectors will be shut off.
