QUESTION: about 95 EX, starts w/out pushing clutch?
yo, i have a question. were all 95 civic ex's able to start without pressing the clutch in? if not, then why does mine? its weird because, i put my autolock on my clutch pedal, for one, in hopes that theives wont be able to start my car, second, they can't put it in gear if it is started. i need to know, thanks
Re: QUESTION: about 95 EX, starts w/out pushing clutch? (EJcoupe)
hmm my guess is that it could be a AT to MAN. swap, when you swap in the '95's you have to re-wire some plugs... when doing that it allows the car to be started without the clutch pushed in... its a magic trick...
Re: QUESTION: about 95 EX, starts w/out pushing clutch? (Steeze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steeze »</TD></TR><TR><TD CLASS="quote">hmm my guess is that it could be a AT to MAN. swap, when you swap in the '95's you have to re-wire some plugs... when doing that it allows the car to be started without the clutch pushed in... its a magic trick...</TD></TR></TABLE>
that's what i was thinking tooo... or the car could have previously had a remote start on it, in which case the clutch safety switch may have been bypassed
Re: QUESTION: about 95 EX, starts w/out pushing clutch? (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 »</TD></TR><TR><TD CLASS="quote">possibly the previous owner bypassed the clutch. thats what i did on mine.</TD></TR></TABLE>
how hard was that to do?
i'd love remote start, winter in PA can get cold
Re: (EJcoupe)
its called a neutral saftey switch. its located under ur dash at the clutch pedal (weird huh?) simply find it and plug it back in and ull be fine.
Re: (VTECschmetec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECschmetec »</TD></TR><TR><TD CLASS="quote">its called a neutral saftey switch. its located under ur dash at the clutch pedal (weird huh?) simply find it and plug it back in and ull be fine.</TD></TR></TABLE>
what color wires?
what color wires?
Re: (EJcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJcoupe »</TD></TR><TR><TD CLASS="quote">
what color wires?</TD></TR></TABLE>
dud stick ur head under ur dash in the driverside floor board. look up the clutch pedal shaft. u will see a plug on the shaft and a plug dangling or might be tucked somewhere. plug the 2 together. and im pretty sure they are covered in some sort of insulation so u wont see a color. but if u dont see the plug someone might have cut it. in that case find a dangling wire that has been cut then simply strip and solder them back together
Re: (VTECschmetec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECschmetec »</TD></TR><TR><TD CLASS="quote">its called a neutral saftey switch. </TD></TR></TABLE>
It's called a clutch interlock switch, neutral safety switches are only for automatics.
The wire colors should be blu/blk and blk.
phokingthai
Transmission & Drivetrain
07-04-2014 01:53 PM
peacexisxfree
05-15-2006 05:37 PM
