problems with check engine light
codes come up knock sensor, idle air control and throttle position sensor
93 civic hatchback with 94 gsr engine using wiring from civic
help
help
Re: problems with check engine light (darkdemon215)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkdemon215 »</TD></TR><TR><TD CLASS="quote">codes come up knock sensor, idle air control and throttle position sensor
help</TD></TR></TABLE>
You have the knock wired up? What color wires does the IACV have going to it? Does the car run/idle at all?
car idles fine except when i hold the gas alittle and it goes up and down slightly
but runs good at low rpm but at high it sucks runs slow
Civic082382
10-23-2010 05:41 PM
EJeff8
05-03-2010 05:07 AM
