pressure washed, now weak start, engine light flickers, and bogs
So I drove home from work and my car was driving really good and I got home waited for about 2 hours then cleaned my engine. I pressure washed it and now when I turn my car on the engine light flickers and it has a weak start also Boggs out when I press on the gas
I never narc'd on nobody!
re: pressure washed, now weak start, engine light flickers, and bogs
https://honda-tech.com/honda-civic-d...sting-3002401/
https://honda-tech.com/honda-civic-d...tions-1998336/
Stickies exist for a reason. Please read them, then fix your post to follow the rules.
Click the two threads I just linked you. Read them both, especially the first one. Click the edit button on your first post, and fix it so that it's in compliance with the rules. It's that simple.
Re: Having trouble!!! Need help please
Agreed. However, doubtful the distributor is "cooked" (but, not to be ruled out).
Remove distributor cap and inspect underside of cap (especially: metal contact points), outerside of cap's metal contacts and coil + igniter for moisture. Also, inspect spark plug wire tips (distributor side) for mosture. Dry both cap and wires as best as possible (use compressed air if available). Do an ECU reset (google search). Put Vaseline on battery terminal and - & + cable leads to help prevent corroson.
Future engine cleanings: put front end of car on jack stands and use rags and degreaser.
If you choose to pressure wash: Cover distributor and alternator with aluminum foil or visqueen + masking tape before spraying.
Re: pressure washed, now weak start, engine light flickers, and bogs
pull the plugs let it dry and try again, if there is water in the spark plug tubes try to get as much out before you pull the plugs
I did this the first time I washed my b series
