Power window troubles.
Old 09-13-2008, 08:15 PM
Lightsped's Avatar
Default Power window troubles.
The car is a 00 Civic SI. When I raise my window it goes up fine, but when it gets to the top it doesn't stop. By that I mean I have to stop pressing the button at just the right time. If I don't stop pressing the button, the window will very loudly pop back down about a 1/4" and go back up, and back down a 1/4". It will continue doing this as long as the button that raises the window is pressed. The window is on the track.
Not long ago, this window came off the track. I took the panel off, lubed the tracks, and it worked fine until now.
I guess what I need to find out is how do the windows know to stop when they get to their upmost raised position?
Old 09-15-2008, 02:58 AM
Lightsped's Avatar
Default Re: Power window troubles. (Lightsped)
Bump for a fun Monday morning.....
Old 09-15-2008, 06:53 AM
civic2489's Avatar
its ur window regulator. take door panel off and look for a big half of a fear looking thing and look at the teeth on them some are probably gone. go get a new one. hope that helps
Old 09-15-2008, 04:41 PM
Lightsped's Avatar
I've never replaced a regulator. How difficult of a job is it once I get my door panel off?
Old 09-16-2008, 09:27 AM
civic2489's Avatar
Default Re: (Lightsped)
its not hard to do
Old 09-16-2008, 09:37 AM
im hench irl
skateboard_ej8's Avatar
It's not too hard to replace a regulator, it's fairly easy. Just take off your old one and retrace your steps, only a matter of a few bolts.
The only tricky part is taking it out of the door. Sounds like you chewed up some of the teeth on the gear. LMK if you need any guidance.
Old 09-16-2008, 09:51 AM
civic2489's Avatar
there are two 10 mm bolts that hold on the glass take those off and take the glass out then there are 4 10 mm bolts holding on the regulator just take it out then follow steps backwards if u take more than six bolts out then u took something off u didnt need to take off make sure u lube up the new regulator as to this is why ur old one took a **** on u always lube them up about every 3 to 66 months and u will be good
Old 09-16-2008, 04:30 PM
Lightsped's Avatar
What holds the electric motor to the regulator? Is the motor easy to remove? I ordered a new aftermarket regulator today, but it doesn't have a motor. My motor seems fine and strong.
Old 09-17-2008, 08:21 AM
civic2489's Avatar
there are three or four screws that hold it on there but the head of the screw is like an allen head i think if i remember right but yea just take those screws off and you should be good
Old 09-17-2008, 08:35 AM
civic2489's Avatar
go to hondahookup.com and become a member then go to mauals and download the service manual for 96-00 civic that should take care of some confusion about ur window regulator i would just post the pages for it but it wont let me right now so just go there and down load the service manual and its free. hope this helps
Lightsped
08-28-2008 11:14 AM
deerman2701
11-27-2007 05:59 AM
Will_H
04-25-2005 12:04 PM
hott-nix
04-03-2005 04:04 PM
EX-T
11-27-2003 07:26 AM
Quick Reply: Power window troubles.
