power mirror switch triggering drivers door unlock
ok this a strange problem, the power mirror switch works perfectly for the passenger side mirror, however when trying the driverside mirror none of the directions do anything except the left side, when pushing to the left on drivers setting it triggers the drivers door unlock. This is a weird problem and im unsure as where to begin trouble shooting this, the switch itself, the floor harness or the drivers door harness? A little about the car, it originally was a 97 dx and i finished doing a power window lock and mirror swap a while back, using parts off of an lx, everything else works perfect, except for the drivers mirror.
The Grumpiest
Re: power mirror switch triggering drivers door unlock
Yes. Your wiring is hacked. Go back and inspect your work. Simple. Unless we're supposed to tell you where you might have messed up.
Well I used factory harnesses and plugs so I was hoping it would all be fine especially since everything else works fine. But thats what I was affraid of, just hoping to narrow down which harness or part since its such a specific issue.
xXViperXx
06-18-2010 10:14 PM
