popping when i turn left
Old 04-27-2011, 11:15 AM
  #26
Bizzle5OH3's Avatar
Default Re: popping when i turn left
Had the SAME THING about 2 months ago. It was the passanger side axle
Old 04-27-2011, 11:18 AM
  #27
SlickC95's Avatar
Originally Posted by lunareg
man, It started doing this when i put brand new ones in, and the f'd up thing is my passenger side wasnt even bad yet, I just wanted to do em all at the same time. I would be so pissed if it was the balljoint, they are my arch enemy.
i know how ya feel when something happens to one side i just replace both sides
Old 04-27-2011, 11:27 AM
  #28
lunareg's Avatar
I hope thats all it is, im gonna snag the axle seals from the stealership and rep out that axle on tues, praying thats all thats wrong, im sick of fixing ****
Old 04-27-2011, 12:33 PM
  #29
xsRevelation's Avatar
im goin cv joint. if it was a ball joint u would prob see some discoloration due to excesive heat from the friction
Old 04-27-2011, 12:35 PM
  #30
I replaced my cv joints but there wasnt always a popping sound just every once and awhile when i turned right. once i took a closer look at them i could definatly see the cracks in the seals. so i replaced them and problem solved for now
Old 04-27-2011, 03:12 PM
  #31
hmonguy918's Avatar
ok... heres my experience from axles popping like that.. ok.. this is wat you need to do..have the hood open and have someone watch while you back out of the drive way turning the way u say it pops..but back out slowly to see where its coming from.. if that doesnt help, jacking it up while it stop wont help either.. it can be this problem that i want to tell you but i dont think you would want to hear it......in other cases it could be your differential on your tranny thats bad...i found this out by having experiences with some cars me and my bro had..you c differentials pop like that too when they go bad.. as i seen before but dont really know if it is that unless im there to c it.. i seen at the race track, some racers weld there differentials to the tranny and they do the popping noise when they turn to the lane.. this is to have limited slip differentials but.. i could be wrong cause like i said.. im not there to c how your car is popping when you turn..
Old 04-27-2011, 03:20 PM
  #32
alphalanos's Avatar
Check all the bolts. especially the lower ball joint castle nut, if they arent tightened correctly it will pop when turning. I had this problem before. Had new bearings, ball joints, axles, inner and out tie rods, etc.
Old 04-27-2011, 03:54 PM
  #33
chilidip's Avatar
If it's the CV joint, wouldn't the boot have failed already and started to leak grease? I recall that's what happened on my old ingetra. Unless it could fail while still enclosed w/o the boot failing first.. that would seem a bit odd..
Old 04-27-2011, 04:55 PM
  #34
lunareg's Avatar
Yeah ill have a look at them all again, we tightened everything with air tools, but who the hell knows right..
I doubt its my diff, this started happening after installed all these new parts.. so it must have something to do with my install. thats why it seems real wierd that the newish axle decided to give out at the same time.
Im gonna go over all my bolts before I do anything else the more I think about it
Skryblz
07-28-2014 09:41 AM
phongadong
05-07-2008 09:12 PM
97Alex
08-20-2005 03:36 AM
hyperlite1080
11
04-14-2004 08:24 PM
Pele
03-02-2003 04:18 PM
Quick Reply: popping when i turn left
