Pop sound
Pop sound
I have a 92 dx hatch and have had a b18c in it for a few days. I,ve put about 300 miles on it so far. Twice, at different times when I let off the gas I heard a kind of pop. It sounds almost like a cv joint when they are going out but this has only happened the two times. Another time was when I accelerated and let off then accelerated again. If I try to make the sound happen I can't. Is this something Accura drivetrains do? I jacked up the car today and spun the wheels by hand back and forth and there is nothing abnormal looking or sounding. Any ideas? Thanks.
_______
_______
Re: Pop sound (fred97gle)
I have the same problem. Sorry I can't help you out but I think it is something in the front suspension or engine mounts. You might want to check that they are tightened well. I've checked mine and haven't found anything.
Re: Pop sound (On Point EK)
Yeah, it could be a loose, or worn mount, and you might be hearing the motor shift backward under load, or maybe even the header tapping the block, if it's stressed by a shortened, or solid mounted exhaust. good luck
Re: Pop sound (rodrez)
I have a DC 4-1 header into a test pipe into the stock exhaust for now. It sounds like it's coming from under the front of the car. Definatey not a backfire.
[Modified by fred97gle, 7:44 PM 5/6/2002]
It's a CV joint. I jacked up the car and looked around and saw some grease inside my left front rim. Cleaned everything up and saw a small, quarter inch split in my CV boot. I shot some more grease in there and rigged up a temporary patch till I can replace it. The noise quit with the new grease.
