Polyurthane Bushings!
Old 05-30-2009, 02:32 AM
Oem eg6 Meo's Avatar
Icon6 Polyurthane Bushings!
so whats Up ive been talkin to a bunch of people and there sayin my ride is gunna be squeeking? what do you think if you got Em in your ride hook it up with some input my homies got some on his srt4 and there straight buts that different setup so i dunno!
thanks Oem eg
Old 05-30-2009, 05:06 AM
jbs
jbs's Avatar
Default Re: Polyurthane Bushings!
I've had ES bushings (Black) on my EG6 for around 8 years, granted it hasn't been a daily in the last 4 years, I do not have any noise related issues. Ofcourse I bought an extra tub of ES lube so I can liberally apply during installation.
Old 05-30-2009, 05:17 AM
jbs
jbs's Avatar
Here is a pic shows how much lube I used back then. Although this was when I was installing the ingals camber kit but you can see the ES lube ozing out and I haven't even pushed the bolt all the way through. (Wow the pic taken 09/2003 brings back the good old days. I don't even have that suspension, exhaust & swaybar anymore and the ingals camber kits looks so new.)
Old 05-31-2009, 09:32 PM
Huh alright cool thats Legit 8 years and no squeeks im good with that But cool well then imma start this project soon so just gotta use a lot of grease then!!! now did you bust this out yourself cuz some said i can Do it and some said i need a bushing press whats the happs on that one? right on Thanks Brotha appreciate that info. did your camber kit make a good difference cuz i was thinkin about gettin one this week? the homie is sellin a brand new in box set of buddy club! whatch you think?
Old 05-31-2009, 10:30 PM
civic_driver's Avatar
Getting the original bushings out is the tough part (you might need a press for this if you don't want to cut the bushings and hammer them out). Putting new ES bushings is easy (I pushed them with my hand and a little help from the hammer).
Old 05-31-2009, 10:50 PM
tazeat's Avatar
I remember Torch + Sawzall hell doing LCA bushings a couple years ago :p
Old 06-01-2009, 01:22 AM
rmcdaniels's Avatar
I lubed mine up good with that grease they come with and they never squeaked. I used a Dremel and a chisel to get the bushing sleeves out, except for the RTA's, which I replaced with OEM using the RTA bushing tool.
Old 06-01-2009, 05:39 AM
joelmatt89's Avatar
i removed mine myself and thought it was very easy i used a hole saw to cut out the metal sleeve and most the rubber, then you just use a sawzall to cut through the metal sleave in 2 spots about a 1/4 inch apart and then it will tap right out. I hate paying for something I could do myself and the guys at the shops I called told me 60+ to do it.
Old 06-01-2009, 09:57 AM
CivicSiRacer's Avatar
I learned a lesson about installing ES bushings. They will not last very long. I had some on my 00 Civic Si from 2004-2006 when I sold the car. Next owner mentioned all the pieces were shredded. Granted this was also my autocross car, but 2 years? I had the reds and they also squeaked a bit.
I heard from ES the black ones have graphite in them.
Old 06-02-2009, 11:37 PM
jbs
jbs's Avatar
If you have access to a press then that would be the easiest way. Granted the press has to be at least a 10 ton one. I did it myself and bought a 6 ton harbor frieght press. . . . . . . needless to say that did not have enough umph! Ended up using hand tools.
RdmptionCivic
Suspension & Brakes
07-02-2011 02:33 PM
JDM95lude
06-17-2007 10:03 PM
thriller
08-05-2005 07:21 PM
92 GSR
04-02-2004 07:47 AM
99ls
08-06-2001 02:46 AM
Quick Reply: Polyurthane Bushings!
