PLEASE HELP!!!! searched
i have a stock swap d15b7 into my 94 eg hatch and the timing is now lined up perfect but when i try to manually turn the crank it turns for a bit then its like it hits something and wont go any further, any ideas?
Re: (wpgcivic)
Can you see if they are all comming up all the way? Or look to see what pistions at the top down the spark plug hole and then look at the set of valves to see if there is one stuck open or something
Re: (cappa)
make sure the up mark on the cam pulley is up and that the two small lines line up with the head, make sure that the big white line on the crank pulley is lined up with the viser in the lower timing belt cover
Re: (CivicTECH36)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicTECH36 »</TD></TR><TR><TD CLASS="quote">nice way to help someone out *******
I guess you're the dumb one</TD></TR></TABLE>
Trial User flaming He was asking him a dumb question...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Dumb question, is it in gear and is the car on the ground?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic »</TD></TR><TR><TD CLASS="quote">the car is not in gear and yes its on the ground</TD></TR></TABLE>
PY2KITR1060
07-26-2022 06:12 AM
