Please Help -Overheat issue (just swapd)
I have a 97 civic Lx 4dr Just did swap D16y7 like my last engine (legit comp tested engine) so im sure wire harness and all is good i replaced a s*** ton of fuses. My temp guage does not work, and soon as the car starts the engine gets hot FAST headers heat up, and radiator hoses get hot also and fan not kicking on. and of course CEL is on, and gives me random codes (7 long and 2 short,7 long 3 short...witch is Misfire LOL) and flashes on the srs light and not the cel light
Re: Please Help -Overheat issue (just swapd)
Just did swap (legit engine) so im sure wire harness and all is good i replaced a s*** ton of fuses. My temp guage does not work, and soon as the car starts the engine gets hot FAST headers heat up, and radiator hoses get hot also and fan not kicking on. and of course CEL is on.
CEL FAQ
Just because the light is on and coolant is hot, does that mnean theres an issue. You definitely need to know how hot and the gauge is the way to go. CEL's are your friend....sometimes.
I checked the CEL and its BS it was 7 long 2 short, 7 long 3 short...Misfire i believe (72 and 73). and its nor idling weird or nothing just overheating.
Also i was reading up on some things, whats the differenceon fan switch temp sensor and just temp sensor.... why would it not show anything on temp guage?
check the cel first then go from there...more info on what kind of car you have and what you swapped in etc. alot of people on here wont help you without the basic info just a heads up dude.
CEL FAQ
CEL FAQ
fix your miss fire and test your fan switch. missing will cause the header to get very hot i have seen cats glow white hot form running on 2 cylinders for 3 blocks.
I'm just playin with ya though, just thought it was kinda pointless and rude
anyway, OP find a working cluster, and see if its ACTUALLY overheating.. hows your thermostat? you said you just swapped it, is there enough coolant in it? has the coolant system been bleed?
@Nickeg9ej1 THERE IS NO MISFIRE. they were random codes...lol cuz idle sounds good.
How do i know its overheating if temp guage not working, well it feels like a sauna after having the engine one for only 2 seconds and builds up....the hoses on the radiator are hot as hell... plenty of coolant did all that.
I just got my tester out and tested the fan switch, guage temp, and the sensor for radiator all the wires are good....must be bad sensors?????? how can all sensors be bad i dont get it.
only had 2 spark plug wires on a ef me and my buddy bought for just the body didnt want to go 20 miles for free wires so drove it to another buddys house right down the road to parked it. probably not the worst Ive done but up there
Unburned fuel collects in the cat and burns inside of it, causing it to glow. This can also destroy the cat or clog it and you won't be able to start your car if it's bad enough.
It sounds to me like your wiring is screwed. Or maybe wrong year ECU or something? The part where you say it blinks on the SRS not the CEL made me think of that right away
Not sure what the plugs look like but are you sure all the plugs are going to the right sensors? Maybe your cluster took a ****? Just throwing out ideas
sorry you werent here for the begginning of the thread, but he didn't specify what car he had or what swap he had in it. hence why i stated that. he edited his post if YOU were reading... just to keep you in the know
cluster seems fine, gas guage works, mph, rpms srs oil cel all work, not showin temp guage and ***** overheating...i was happy when i did the swap until this happend. **** sucks
1. Did the temp guage in the cluster work BEFORE the swap? Yes/no?
2. Did you burp the coolant system of all air? Yes/No?
3. Is your radiator fan kicking on? Yes/No?
3. Have you checked compression? Yes/No?
if your engine coolant sensor is not working, it cannot tell the ecu to kick on the rad fan... Jump the fan to the battery and see if it still get hot...
Well, how about we ask some very simple questions and NOT get indirect answers shall we?
2.yes burped it put it in the head all that(done this many times)
3.compression is tested at the factory where i got it with a 30 day warranty 160comp(they cant sell without comp test). i drove it around felt good no idle problems just this lil delima with guage and overheating.
