Please Help B16 engine with gsr cams shafts.. ???
hey i got some gsr cams shaft laying around my house and i was wondering if i threw them on my b16 si engine would it help me out with some ponys or make pony po po.. i just thought at it and was wonding" hey gsr take itr cams and throw them on and they make hp,, so why cant si take gsr and throw them one to make ponys too?? please someone drop me a line i really want to do this soon
Former Moderator
Re: Please Help B16 engine with gsr cams shafts.. ??? (Houston Hatchback)
I'm sure the gains are not worth the trouble unless you have a 1st-gen B16A.
If I were you I would just buy a CTR intake cam - it's the best O.E cam that you can buy, and the exhuast cam isn't as necessary.
Where do you buy a CTR (Civic Type R) intake cam?
Here's a few places:
http://inlinefour.com/ctrcamshafts.html
http://jdmhondaparts.com/frameset.htm
$350.00 or so is not bad at all for a good cam. Add camgears and some fuel tuning and you should see MUCH better resluts than you would with GS-R cams and the same tuning.
The CTR cam has higher lift and longer duration than any other Honda cam - including B16A, B18C1, B18C5/B18C (ITR), etc.
Good luck, and nice hatch you've got there!
Re: Please Help B16 engine with gsr cams shafts.. ??? (B18C5-EH2)
There will be gains will be really small. if you plan on doing it yourself...then go for it. Wont cost you anything
You'll gain a little in the mid range, but the top end will be about the same. Not worth the sweat, just save up for a CTR intake cam, it'll be worth it.
Re: Please Help B16 engine with gsr cams shafts.. ??? (riot)
Time=$
Time=$
Re: Please Help B16 engine with gsr cams shafts.. ??? (YokohamaSiR)
If you don't mind doing the labor yourself, then I'd go for it...every little bit helps. I would't go pay someone to do the cam install...not worth the $$.
revolt_allmotor
09-21-2004 02:35 PM
