PLEASE HELP!!!!!
PLEASE HELP!!!!!
My car is burning COOLANT. Well like 2 weeks ago my radiator went out and my car overheated so i replace it with a FLUIDYNE radiator and ever since. My car has been buring coolant its not a lot and olny burns when i drive it hard. could i have blown headgasket? I have a little white somke that come out of the exhust but i think its b/c its cold out its stops when my car warm up so what is it? PLEASE HELP
Re: PLEASE HELP!!!!! (TodaPwr)
First :Calm down
Second: Are you sure your car is burning coolant? It might be leaking from somwhere.....check that first.
Third: The white smoke you are seeing is due to your car running rich.....atleast thats what I would assume.
Last: Be patient, someone will know whats wrong or will help someone else figure the problem out.
-Anymore info would be helpful
Re: PLEASE HELP!!!!! (dohcVTEChatch)
Haha thanks for the post I'm 99.9% sure that its not leaking. but for runing to rich that can be ture how can i fix that
how do u know its only burning when u drive hard? whats happening to make you say that? trying to get some ideas of what else u are expierencing so I can poss. help ya
Re: PLEASE HELP!!!!! (Grimace EJ6)
i can smell a sweet smell inside the car and under the hood and i check the coolant last night before i went playing in the snow it was full in the overflow and after i got done drving it hard it went down to a 1/4
sounding more and more like coolant in the exhaust.
one way to check a blown head gasket that ive learned is to pressurise the coolant system and let the car sit over night.
basically take the radiator cap off and get a cap and a pump to pressurize it, then the next day with the spark plugs off crank the motor over with the ignition disabled and a paper towel over the plug holes to see if the cylinders spit coolant out.
ive found a few tricky blown ones that way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaPwr »</TD></TR><TR><TD CLASS="quote">i can smell a sweet smell inside the car and under the hood and i check the coolant last night before i went playing in the snow it was full in the overflow and after i got done drving it hard it went down to a 1/4</TD></TR></TABLE>
if u can smell it, ur def either leaking or burning coolant. I would do the test for a blown head gasket like EG TYPE-R explained. could be a small leak which is why the car isnt overheating yet. also if u can smell it inside check the heater core. may be leaking from there
92GSR
07-29-2002 08:16 AM
