pivot engine push button start - need help with installation
i bought this push start and the instruction came in Chinese i think. there are 4 wires coming out from the black box. 2 blue wire, 1 red wire and 1 black wire. anyone here knows which wire goes to what. thanks
Re: pivot engine push start help
There is four wire on this push start Blk box. I have a volt meter, but what wire to I need to lOok for?
There is a lot of theif on these cars and this is something I'm trying to throw on to slow them down if it ever comes later.
The starter? Like Breaking into the ignition and Turning the ignition to trigger the starter, but it can't Start cause it's wire is to a button push start that will signal the starter??? I was
Thinking this..
the rear ignition white cap from the back can be pop out and be turn as a key from there. So if I can put a push start on and with that being done it can't start the car. This was
Just what I was thinking. Not sure if it will work 100% this way until I get it install and tested.
