Picked up a o2 sensor from the junk(pics)
i have to extend it witch will ruin the 7 day warranty i have on it. im pissed the bung is located under the motor ....and the connector is near the side of the transmission
what are my chances this o2 sensor is bad, and is their another option i can go about instead of extending my o2 sensor
Re: Picked up a o2 sensor from the junk(pics)
i picked it up for 40. the new is 80 , i have to pay 20 to extend and install. i had only a certain amount to play with.
do these things go bad easy ..theres no way to test it?
and to be more specific its not your average junk, its more of impounded,wrecked, bought from auction . i didnt get this my self i went to a front desk and they went and got it for me....
You're spending to much on "labour" this would be a 15$ job max 5-8$ o2 sensor and 3$ for 2ft of 14g wire plus 1$ for an exacto knife to strip the wire back.
yeah i know , its easy i bet if you know what your doing. i've never spliced any wires together..and i sure dont want to try on this sensor...i will take your advice though and learn because it comes in handy obviously
seperate the O2 wires from the wiring loom then re route them to the back, then tape them back up. I did this with my z6 harness when I swapped in my B16 no need to extend or cut the wires. Also denso direct fit O2 sensors go for like $30-40 on amazon brand new
are you sure, this o2 is from an integra obd 1 like mine it fit, i dont need a different o2 i just need to avoid cutting it up so if its no good i can return it for another, im going to suggest it to my mechanic are you sure
Oh look, I can change this
Return it already, get refund, then buy a BRAND new one that is a direct fit. Can't believe I'm having this conversation. You don't spend a dollar to save a nickel.
Look at these prices: http://www.rockauto.com/catalog/rafr...&parttype=5132 ... exact fit Denso is $48 ... and there are ones cheaper than that.
here is one from amazon for 35 shipped
OP will try to put some pics up tomorrow to show you what i mean about separating the wires from the loom
also this is assuming you are using your original harness
where i got this o2 is where i get my alternators,iacv etc never had a problem except one time with this alternator..but he gave me another one no problem but this o2 is going to be spliced so ill play with it and see if it works if it dont **** it its only 40 bucks next week ill get a new one problem solved , ill keep you guys posted
