pic of idle adjustment screw????
where is the screw on my gsr swap to adjust the idle??????????
my idle is crazy im thinking its my iacv but im not 100% , im not getting that code either!!
thanks
thanks
Re: pic of idle adjustment screw???? (sirhatchalot5)
it is on the side of your tb facing your intake. It takes a flathead screwdriver to adjust so look for a screw that looks like that. Are you sure you don't have a vacuum leak somewhere?
If you have never messed with it, it is not visible, there is some thing covering it, just scrape that off and remove it and you can see the screw then.
sik_sol
08-18-2006 02:08 PM
