PGM-FI RELAY (any posibility of it causing no spark?)
like the tittle says no spark, is it posible for the pgm-fi relay to prevent a spark...or is it solely fuel managment,(all dist internals show correct resistance. and voltage, but the dam thing wont spark even right off the dist.
HT Order of Merit
Re: PGM-FI RELAY (redrocketgsr)
When you put the key to the RUN position and all your dash lights come on, does your check engine light come on for a second and then turn off? Does it turn on at all? Check the ground on the engine by the thermostat housing. If its not a good ground you wont get spark.
Re: PGM-FI RELAY (JDM_Ej)
ground good, and i didnt bump it my roomate did, just for the hell of it. check light comes on during its check cycle then turns off.
Like u said up top is ur pgm-fi relay bad?? If it is replace it and just see if it makes a difference.... if you dont have a relay laying around see if another relay is the smae as that one... say a headlight relay etc.... then switch them out to see if it helps.
the main relay fix... http://www.markl.f9.co.uk/howt...y.htm
for the record, yes it can stop spark. it tells the ECU that the ignition is on.
kamakaze1
01-24-2006 03:47 PM
