People with OE civic foglights on 92-95's....
i am looking into purchasing/installing a set.....the wiring shouldnt be a problem, my only concern is.....what all must be cut out to fit the plate in.....also, did you have any difficulty getting the setup to slide in perfectly/aim correctly??? thanks in advance
Re: People with OE civic foglights on 92-95's.... (markpaco)
anyone know how to wire it up so they dont turn off w/ the highbeams on or how to put em on w /the low beams off?
Re: People with OE civic foglights on 92-95's.... (lucas569)
By using a relay found at Radio Shack and some wiring you could have them on but when you change to highbeams it will cut them out or vice versa.
Re: People with OE civic foglights on 92-95's.... (SpoonFedHatch)
What I did was wire them into an extra spot in the fuse block underneath the dash. They don't go off with the highbeams, but must have the parking lights on to work.
Re: People with OE civic foglights on 92-95's.... (Bigjon)
using extra position #3 on the fuse box will alow you to have power to the switch anytime the car is the on or run position.
So if you have the factory wiring just run the input side of the 15A fuse holder(the bigger red wire) to the #3 spot on the fuse box.
This way you can keep the fogs on all the time and have them shut off automatically with the car, and they dont shut off with the highs on.
Re: People with OE civic foglights on 92-95's.... (skunkwhat)
great info!
Sean EH2
03-26-2007 07:42 AM
