PCV valve location
Old 12-10-2002, 04:53 PM
lonefuzzy79's Avatar
Default PCV valve location
Where does the PCV valve conect to the block? It starts at the top of the intake and them goes through between the 1 2 intake runners and then connects to what? thanks in advance...
Old 12-10-2002, 05:40 PM
In The Garage
Shawn C's Avatar
Default Re: PCV valve location (lonefuzzy79)
it aint even be tryin to connect to the block, doo. j/k it goes down into a little black box kind of under the intake manifold. just pull on it. its in a rubber gasket thing in the top of that black metal positive crankcase ventilation box. it really helps too if you mention what car you have. so this is really just an educated guessaroni.
Old 12-11-2002, 09:51 AM
Default Re: PCV valve location (22lbGS-R)
Right, its a D16Z6 thanks for the info I will keep looking
Old 12-11-2002, 11:11 AM
brcivic411's Avatar
as was mentioned, it is under the intake manifold; in the black oil separator box that's on the back of the block
Yeah Daybid
01-06-2010 01:42 PM
My_EFsedan
12-20-2009 09:00 AM
efjones9
04-20-2009 09:01 AM
K i l l a B e e.
03-04-2009 10:31 AM
Otherguy
04-13-2005 05:41 PM
Quick Reply: PCV valve location
