Painted My Wheels Pics Inside (56k Beware) Shit i am only 28.8k
Guest
Posts: n/a
Painted My Wheels Pics Inside (56k Beware) **** i am only 28.8k
Well when i took them off i was being a dumbass and broke a lug.
Then i cleaned them and started painting.
It started getting cold so i turned on the heater.
And after 4 cans of paint and 12 light coats on all the wheels this is what they look like.
This is the next morning after they finished drying and i installed them.
All comments welcome.
BTW Here is a How-To.
1. Take the wheels off the car and clean them. (i used a rotory grinder with a scotch brite pad then just a little hand scrubing it worked great )
2. Get some 320 grit sand paper and sand them.
3. Put index cards in between the rims and the tires to keep the paint off the tires.
4. Spray one coat of primer and make sure it is completly covered.
5. Get out your paint that is the color that you want and start spraying making sure that the paint drys between each coat.
6. Put the wheels back on and enjoy those bitches.
[Modified by BLACK DEATH, 11:48 AM 4/8/2003]
Re: Painted My Wheels Pics Inside (56k Beware) **** i am only 28.8k (BLACK DEATH)
Your rotation is on the tires is backwards up front
[Modified by eg cookiemonster, 7:28 PM 4/8/2003]
Re: Painted My Wheels Pics Inside (eg cookiemonster)
________
Motor manufacturing indiana
Guest
Posts: n/a
I recommend you use clear coat as well at least 3 coats of it, I would let each coat sit a night just to ensure it's cured and dry. Just another tip when painting your wheels it might cut down on chipping off as well and add some durability. Me I stay away from spray painting wheels. You can't beat powder coat.
Guest
Posts: n/a
Re: Painted My Wheels Pics Inside (purek9hybrid)
not to bad man.... i kind of like the stock look of del sol rims. Maybe if they were GSR rims they would be cool flat black.
Is your car still up on the jack or somthing, I had a delsol and i dont remember it being that high when i first got it. Lower that **** some beotch. sorry just tryin to help you out BRO.
Re: Painted My Wheels Pics Inside (BLACK DEATH)
So you're telling us that the little writing on that tire that says "ROTATION>>>" is facing the front of your car???
Sorry, I've never seen a unidirectional tire with the tread facing that way. The tread isn't able to push water out of the way effectively in a rainstorm when the ">" pattern is pointing toward the back of the car.
Guest
Posts: n/a
Re: Painted My Wheels Pics Inside (gamby)
They do not look like this
so they wet the water out from in the tire all the same no matter what way they rotate
oh yeah i am sorry about saying unidirectional what i meant was it didn't matter which way it spun not that it was only meant to spin one way.
New User
looks like my car
You should have seen what the wheels looked like before. The former owner curbed the wheels an insane amount. We actually used bondo to fill in the holes. Its held up almost a year
Re: Painted My Wheels Pics Inside (93delsol)
Re: Painted My Wheels Pics Inside (buddha429)
BONDO.... man's best friend... btw, nice wheels
Re: Painted My Wheels Pics Inside (rainmanEK)
another painting job, so people can get a look see at a hatch with painted wheels :
https://honda-tech.com/zerothread?id=448696
oh, and they are holding up pretty dang well since i painted them.
