PA obd1 inspection
PA obd1 inspection
Sorry, I did search and I found nothing on what my question is. I'm getting a 94 dx coupe with an obd1 gsr swap. My question is what does Pennsylvania do for OBD1 inspection. What should I look at on the coupe to see if it will pass inspection? Thanks in advanced.
Re: PA obd1 inspection
For PA inspection then are required to do a visual check of your emissions cat, 02 sens ect. depending on where you are there will be a emission test. It is a test of your gas cap to make sure it is not leaking fuel vapor. The bigger part of it is the mech inspection brakes, ebrake functions, tire tread depth, exhaust system, suspention (tie rods,ball joints, shocks ). Really PA is not a hard state tp get a car through inspection
