P2J-3 95 D15B or D16y8?
Old 05-25-2005, 04:07 PM
civicboisi's Avatar
Default P2J-3 95 D15B or D16y8?
looking at http://www.sohchonda.com/ipw-w...t=135 i guess i have the d15b...but why would he have (2) by the vtec solenoids?
Or is it a y8...but the y8 is stamped with 99 on the right side...weird
Old 05-25-2005, 04:08 PM
Electrician
Deemeetree's Avatar
Look at your block, it's stamped there.
Old 05-25-2005, 04:17 PM
civicboisi's Avatar
Default Re: (Dimitri_EG8 a.k.a. Dimi)
i just bought the head...no block...came off of a a6 though mini me...
Old 05-25-2005, 04:23 PM
wilham320's Avatar
Default Re: (civicboisi)
if you have two vtec solinoids, then it's a jdm ek obd2 sohc... it's a "fuel efficient" head.
Old 05-25-2005, 04:25 PM
civicboisi's Avatar
Default Re: (wilham320)
i have one
Old 05-25-2005, 04:33 PM
wilham320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicboisi &raquo;</TD></TR><TR><TD CLASS="quote">i have one</TD></TR></TABLE>
so what are you asking then?
Old 05-25-2005, 06:02 PM
civicboisi's Avatar
which head do i have...the D16y8 or the D15b?!
Old 05-25-2005, 06:36 PM
civicboisi's Avatar
anyone?
Old 05-25-2005, 07:13 PM
NASIOC.com
Otherguy's Avatar
did u put the dizzy on?
*edit* let me see the cam gear
Old 05-25-2005, 07:16 PM
civicboisi's Avatar
Default Re: (Otherguy)
distributor came with head...i'll take pics of cam gear...*says 1.6 on it*
Old 05-25-2005, 07:18 PM
e jay one's Avatar
i have a y8 head sitting in my garage and its stamped p2j-5 if that helps.
Old 05-25-2005, 07:19 PM
EK k kay's Avatar
P2J is most likely a y8 head.
Old 05-25-2005, 07:20 PM
civicboisi's Avatar
Default Re: (e jay one)
that stamp would be right...
Old 05-25-2005, 07:39 PM
civicboisi's Avatar
OBD0 plugs?
1.6 Cam Gear...little wet, but thats what it says...
The y7 is a P2F something...weird but it came out of a 98 with a 97 stamp
Old 05-25-2005, 07:43 PM
e jay one's Avatar
yea those plugs look pretty old.
Old 05-25-2005, 08:09 PM
NASIOC.com
Otherguy's Avatar
that REALLY doesnt look right...
Old 05-25-2005, 08:13 PM
civicboisi's Avatar
im confuzzled...need to know too to get the right parts...
well i looked up my y7 numbers and its right on...(the link above)...just this head is weird, dunno whats what...
Old 05-25-2005, 08:14 PM
RTFM
v4lu3s's Avatar
if it has 2 vtec solenoids its the 2 stage vtec obd2 head. gets as good a fuel milage at best as teh vx/hx models but makes 127 or 130 hp.....
oh yeah and that distributor sure does look like the one found on a d16a6.
Old 05-25-2005, 08:18 PM
civicboisi's Avatar
Default Re: (v4lu3s)
okay...what do you guys mean by 2 vtec solenoids? i only see one...or is it a internal thing?! Could you guys tell from the picture i provided? Or need a side or back shot of it to tell?
Also, if it were a obd2, would the obd0 bolt to the head no prob? Kinda weird don't you guys think?
Old 05-25-2005, 08:24 PM
civicboisi's Avatar
ok well even if it is an a6 distributor...i could use a z6 distributor in place of the y8 right?
Old 05-26-2005, 03:57 AM
civicboisi's Avatar
Default Re: P2J-3 95 D15B or D16y8? (civicboisi)
up for an answer...
Old 05-26-2005, 07:09 AM
HumanResource's Avatar
I only see ONE VTEC solenoid
And a Dist Plug that kinda looks like another
For sure it's Single VTEC
It's JDM since there's no US serial Numbers above the exh (unless it's Canadian)
P2J = 96^ SOHC VTEC head casting (same as our D16Y8)
So you can say it's JDM SOHC VTEC 96^
P2J is the same head casting for the D16Y8 and the 3stage VTEC D15B, but no secondary VTEC Solenoid means it's SINGLE
The valvetrains on both are COMPLETELY DIFFERENT!!!
Old 05-26-2005, 01:27 PM
NASIOC.com
Otherguy's Avatar
Default Re: P2J-3 95 D15B or D16y8? (HumanResource)
the z6 dizzy and the y8 one are in different housing.... so it will fit but only with one bolt, thats how mine is
Old 05-26-2005, 04:24 PM
civicboisi's Avatar
okay well i guess it might be a JDM EK motor? So in order to ues this in a mini me setup, id have to use the USDM d16z6 distributor correct? Also with the P28 ecu...
*its going into the EG9 btw*
AND what are the differences with the valvetrain? Hotter more aggressive cam? More peak HP/TQ? Elaborate more please...
Oh and i called Honda...they don't know either...parts guy said the head was made with VTEC using a OBD0 distributor ONLY in Japan, thus making the head POSSIBLY a JDM head. Everything just doesn't make sense...
Thanks for the help so far!
Old 05-26-2005, 06:44 PM
Vinceg99's Avatar
Bump cause I would like some info on this as well!
Quick Reply: P2J-3 95 D15B or D16y8?
