only 2 cylinders firing! HELP!
#26
Re: only 2 cylinders firing! HELP!
Diagnostics will.
Do as RonJ has outlined, TEST the spark plugs (don't just unplug the wires), Check timing (Ignition and mechanical), test your distributor coil; etc.
Ultimately, if you still can't get it working, create a thread outlining everything you've done, be precise.
#27
i timed it like 8 times ..i hit the injectors with a noid light they are fireing, i also listened to them with a stepthascope they are clicking also excuse my spelling but i also used a spark testor i am not sure if the flame should be bright blue but it was yellow ish and sparking, another thing i checked was cap and rotor visually it looked good but idk what good looks like the only thing i have not done was a cylinder leak dwn test, excuse me not knowing too much abour hondas but any help or thoughts is appreciated
#28
Please create your own thread rather than post in this old one. When you make a new thread, describe the problem in detail and also give details about your set up.
shivic
01-04-2004 04:36 PM
