Ok this sucks
Ok this sucks
So yea i'm trying to do my first oil change since my swap was done and the drain bolt is so damn tight i cant even budge it....any ideas?
Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">don't tighten it so tight next time. (you did change the oil RIGHT AFTER installing the engine right?). also, use a breaker bar and a good 6pt socket</TD></TR></TABLE>
Yea it was the guys that did the swap I didn't do the swap myself. Never done one and I don't have the proper tools Anyway I got it...just needed more pressure.
1 Post
Re: Ok this sucks (Blazin Civic)
NO SOCKETS.... get the correct sized BOX end wrench, a length of pipe that fits over the wrench and try that.
If it ends up getting stripped out. - you can replace the oil pan (extreme) or you can get a tap and die set and attempt to repair the threads, or you can purchase a new oil drains plug that has larger diameter threads and tap your oil pan to fit the new drain plug.
BTW - take the oil pan off of the car when using a tap and die.
Re: Ok this sucks (roadracewade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roadracewade »</TD></TR><TR><TD CLASS="quote">Air gun always does the job right! </TD></TR></TABLE>
youre an idiot
just take a wrench and bang on the end with a rubber mallet works like a charm
youre an idiot
1 Post
Re: Ok this sucks (alotawatts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alotawatts »</TD></TR><TR><TD CLASS="quote">Use a breaker bar. Or find a length of small pipe to extend your ratchet length / leverage.</TD></TR></TABLE>
def what i would do
def what i would do
Re: Ok this sucks (B16aDasher)
I've always had luck using my teeth. Just get a mouth full of that sucker, bite down hard, and twist. You'll never look back on all those expensive, bulky sockets and wrenches.
