Ok..electrical questions- EBRAKE light stays on even after I release it. Plus few more..
If youve read my other thread in tech you'll know that my car has been apart the last 2 months. Gone through a huge rebuild. Anyways, Ive got a few electrical questions. First, My left turn signal idicator light stays lit just dimmly even when the signal is turned off. The ebrake light stays on even when the ebrake is taken off. I also have a left headlight which seems to stay dim, but I figure thats just because Im still missing one ground in the engine bay. 2 of 3 is all I have on right now.
Re: Ok..electrical questions- EBRAKE light stays on even after I release it. Plus few more.. (Tur*bL
I need help on the brake light question too. Mine flickers when I drive, until I smack the **** out of the handle. Is it just stuck?
CHECK YOUR BRAKE FLUID!!!!!
when your fluid is low, the ebrake light will come on. my friends came on at the track in his RSX. checked his drivers manual, low brake fluid, he killed the brakes in one session.
If you have two wires going into the brake resevoir cap there is a sensor in there.
If that goes bad it will cause the light to go on.
Cool thanks, I actually had no fluid in it at the time. Ive since then bled the brakes and filled it with fluid. Light should be gone, forgot to check that last night. thanks.
breadmanzip
07-06-2004 09:47 AM
