oil light stays on at start up.
Old 09-07-2011, 09:11 PM
PwrdByVtec_EM1's Avatar
Default oil light stays on at start up.
Hi Honda tech. Im having an issue with my oil light. When my car is cold and i start it up my oil light will stay on for a few seconds. Even after all the dash lights go out. My car burns a bit of oil but im always regulating it.
could it be the oil pump?
1999 civic si b16a2
Old 09-07-2011, 09:16 PM
Fliptard's Avatar
Default Re: oil light stays on at start up.
Change the pressure sensor. If that still happens, possibly the pump not pumping enough oil when it's cold, because it's thicker, it is harder to pump as much as when it is warm/thinner. So change the pump.
Old 09-07-2011, 09:25 PM
Former User's Avatar
Don't drive the car until you measure the oil pressure.
Old 09-08-2011, 05:00 PM
I do use a thick oil Val. vr1 20.50.
is an oil pump a pain in the *** to change?
thanks for the diagram and the info.
Old 09-08-2011, 05:13 PM
hyperblu's Avatar
Yes.
Old 09-08-2011, 05:18 PM
Linked's Avatar
uhhh, 20w-50 is TOO thick. and put the emphasis on TOO.
you need to switch to 10w-30 at the least and hope you didn't starve your valve train
Old 09-08-2011, 05:22 PM
Fliptard's Avatar
10w-30 when it's hot, 5w-30 when its cold out.
Yea, the oil you are using is wayyyyyyyyy to thick.
Change asap before u blow a rod bearing
Old 09-08-2011, 05:25 PM
DeanHondaPGH's Avatar
Damn. why are you running such a high viscosity oil.
Old 09-08-2011, 05:41 PM
Master Detailer
98civdx's Avatar
Drain that ****ing oil out before you really cause some damage.
Thick oil is going to be quite hard for that pump to move around when it's cold.
I run 5w30 year round, no matter the temp.
Old 09-08-2011, 05:43 PM
Me too, though I live in Houston.
Old 09-08-2011, 06:03 PM
furious94ls's Avatar
These cars never need anything more/less than 5w30. If your enging burns too much oil replace/rebuild it.
Old 09-08-2011, 07:09 PM
Master Detailer
98civdx's Avatar
haha
I have really never seen the point in running different oil in different seasons.
Old 09-08-2011, 10:55 PM
okay ill my oil asap...i do a lot of highway driving and with the type r tranny my rpms r usually high as heck....i kinda figured that oil was too think for my oil pump to handle in the mornings.
Old 09-08-2011, 10:58 PM
joeshmo's Avatar
I know alot of people run thicker oil to compensate for leaky valve rings and seals. The thicker oil burns/leaks slower as it has a harder time getting into those little spaces. This is fine for older, larger engines but for small foreign engines, it is not a good idea as the clearances are much tighter and will not receive adequate lubrication using a high-weight oil. If it were a 302 or any other big honking v8 you'd be fine.
Old 09-09-2011, 03:24 PM
Makes complete sense. Thanks for the quick lesson haha
Old 09-09-2011, 06:33 PM
jamesd86's Avatar
ha, i used to run gear oil(thicker than 20-50) in my dodge shadow cuz it had a bad leak at the end of the cam. ended up trashing the engine because of this..deff get that stuff out with the quickness.
Old 09-09-2011, 06:35 PM
joeshmo's Avatar
I've seen people do similar with lebarons (with a mitsubishi v6, same as in the 3000gt) to prevent tapping valvetrains. The most I've seen used is 20-50 though.
Yuta
13
11-11-2016 05:32 AM
ricky28
05-12-2014 03:38 PM
boost4life1
01-26-2013 06:27 PM
young geezer
10-13-2011 07:07 PM
cornholioEK
01-17-2003 02:52 PM
Quick Reply: oil light stays on at start up.
