Oil Leak...
Oil Leak...
Wassup guys, i currently still have an SLIGHT oil leaking problem on my 94' b18b. I noticed a while ago a build up of oil under the cam cap so i replaced that and it seems to have taken care of it, but every few 100 miles or so i notice a slight accumulation of oil right underneath the cam cap and somewhat near the dizzy.
Can you guys please give me some input as what can be causing this leak and how i can take care of it. I will try and take some pictures.
Thanks, John
Thanks, John
Re: Oil Leak... (nY's FiNeSt)
have you checked your valve-cover gasket? Sometimes if you don't have some silicon sealant or something right at the corners and around the cams it will leak a little
Re: Oil Leak... (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=665117
https://honda-tech.com/zerothread?id=700456
https://honda-tech.com/zerothread?id=652966</TD></TR></TABLE>
thanks for the info, i should've searched first
