oil in intake mainfold
Re: oil in intake mainfold (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">what would oil to in intake mainfold?</TD></TR></TABLE>
I believe you meant to say "why would oil be in my intake manifold?"
Re: oil in intake mainfold (IWANTAHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IWANTAHB »</TD></TR><TR><TD CLASS="quote">I believe you meant to say "why would oil be in my intake manifold?"</TD></TR></TABLE>
You are correct. But I am still thinking about his question, so I can't be of any more help at this time.
-Shane
-Shane
Re: oil in intake mainfold (nighttrain33)
check your PCV valve the item no one ever remembers to change every year its only like 5 dollars to replace it its not working properly it will suck the oil from valve cover down through the vacuum hose and into your intake mani.
Re: oil in intake mainfold (92civichatch1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civichatch1 »</TD></TR><TR><TD CLASS="quote">check your PCV valve the item no one ever remembers to change every year its only like 5 dollars to replace it its not working properly it will suck the oil from valve cover down through the vacuum hose and into your intake mani.</TD></TR></TABLE>
or crank case
or crank case
Re: oil in intake mainfold (brick top)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top »</TD></TR><TR><TD CLASS="quote">
or crank case</TD></TR></TABLE>
Huh?
For those who dont know: PCV = Positive Crankcase Ventilation.
Huh?
Re: oil in intake mainfold (LowSlow93Sol)
he mentioned it sucks from the valve cover. some also suck from the black breather box on the block for the crank case.
A lot of the time oil in your intake mani means your piston rings are gone. With extensive amounts of blow-by the preassure blows oil from the valve cover through the pcv system into the intake manifold, with the experiences i've had. But every situation is different. Try a compression test
Raocorp
10
04-27-2003 02:22 AM
