Oil Is EVERY WHERE!
Oil Is EVERY WHERE!
i need help i got 2 striped bolts on my z6 head got oil also coming out of a spark plug the car goes threw SO much oil its crazy post links to the parts i should buy to fix it please 93 del sol d15b7 with z6 head on 8 psi straight piped if need to know more let me know i just need to stop this leak so i can tune my car
please help
please help
Re: Oil Is EVERY WHERE!
Just get a new block lol can probably be had for 2-300$....why are you even running it knowing 2 head bolts are loose/stripped
you can try re taping/threading the holes but personaly if I had a d-series I'd just go get a new block and swap it in imo it's easier in the long run.
idk if holes are striped just the top half of the bold was flat and bottem looked normal and it just keeps spinning sorry im pretty knew to this car and dont want to have to pull the engine just to fix it.... u know what i mean?
pic of bolt(s) ? if it just keeps turning and turning there's a good change the threads in the hold are stripped. stripped head bolts a major pain regardless.
yeah it keeps turning and turning and sorry dont have camera phone or camera in general to take picture with i will try to find a picture on the internet just like it tho
in reality the easiest option is to re-thread the holes I've never done it or tired so i can't say how easy or hard it is but would more then likely be a under 80$ repair tools and such included. 2nd option is find another d15 block and swap the blocks and get new bolts all around in fact I recommend that regardless which one you do. on the bolt try picking at the threads if you get shavings coming off those are the threads that were in your block and you're going to need to do one of the 2 options. you'd be extremely lucky if some how only the threads on the bolt got damaged. Sorry that's just the truth of it not trying to scare you
you did use a torque wrench when tightening them right ? and did it in the 3 steps. Same with undoing them except it's no more then a half turn on first "brake".
vaypourus
10-31-2006 11:08 AM
