Oil burning.
Oil burning.
I have a 94 civic hatch dx, its burining oil from somewhere cant find the leak, my dad dosent think its the oil pan gasket or cam seal/crank case seal? i wanna do it my self,but idont really have the tools too.. any suggestions on what it could be??
Re: Oil burning.
Is it burning oil (out the exhaust) or is it leaking from somewhere in the engine bay? You have to de-grease the engine. Then let it run and see where it is coming from.
Common places are:
-Distributor gasket
-Valve cover
-Valve cover bolts
-Cam seal
-Oil pan gasket
-Rear main seal (inbetween engine/tranny)
-Spark plug grommets (pull the plug wires and see if the tops of the plugs are wet)
Common places are:
-Distributor gasket
-Valve cover
-Valve cover bolts
-Cam seal
-Oil pan gasket
Re: Oil burning.
nope it burns on the exhaust and stuff. it like drips from the front of the motor and then back as i drive,okay ill have to do that tmr and see what i find.
Re: Oil burning.
It's leaking from under the car onto the exhaust? Or the top of the exhaust manifold? If under the car I would guess it's the oil pan gasket. Clean it all up and report back.
