OEM Honda ITR cams in a B16a2
IF you swap ITR or CTR cams into a B16a2 do you have to get a VTEC controller to change the VTEC RPM from 5500 to like 5800? Someone said this. I dont believe it.
Re: OEM Honda ITR cams in a B16a2 (CDM SiR)
You should get a VAFC and dyno tune it to get the best gains from it. If you just slap the cams in it might even make the car slower! Yes, you will probably need to change the VTEC x-over.
s
s
Re: OEM Honda ITR cams in a B16a2 (stevel)
if you go with ctr or itr cams
just get the intake cam
exhaust cam is pretty much the same on the Type R and GSR and B16A
vafc cam gears and tuning and you should see some results
New User
Can you just slap in the intake cam? I dont want a V-Afc, if so what kind of gains would I see?
[Modified by bishop, 12:27 PM 9/27/2002]
Re: OEM Honda ITR cams in a B16a2 (bishop)
i dont understand why one would buy cams and not want to maxamize their gains by not getting them tuned.
lack of money??? but hey if ur gunna do it, do it right
Guest
Posts: n/a
Re: OEM Honda ITR cams in a B16a2 (DarkKnight[DMD])
i'd recommend a Hondata ECU instead of the V-AFC.
IMO, any time you replace the cams and/or cam gears, you should get it dyno tuned. Just slapping on new cams will only hurt you in the long run. Don't be a ricer, and just start installing **** because it's cool, and letting your friends know you installed cams. Why don't you throw on some strobes and neon nozzles go boot.
dLo GSR-stolen-now-WRX
12-18-2002 05:34 PM
