OBD2 gsr, which is primary O2 sensor???
i have an obd2 gsr and i am converting to obd1, which sensor can i disconnect? the one in the cat or the one in the header collector? i need help quick. thanks alot
Re: OBD2 gsr, which is primary O2 sensor??? (tyflip2)
the one in the cat is the one you can disconnect. obd1 runs off of the header collector o2 sensor.
Re: OBD2 gsr, which is primary O2 sensor??? (anothersickhatch)
alright thanks for the help. is this a for sure answer? because i remember when i first got the swap and that sensor was not in the car ran like **** so i want to make sure i undo the right sensor!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anothersickhatch »</TD></TR><TR><TD CLASS="quote">the one in the cat is the one you can disconnect. obd1 runs off of the header collector o2 sensor.</TD></TR></TABLE>
The man is right.
The man is right.
