obd1 sensor HELP
Old 12-16-2008, 01:59 PM
mxjosh's Avatar
Default obd1 sensor HELP
ok..i just swapped a sohc vtec zc into my del sol..that originally had a d15b7
everything electrical hooked up..BUT...there is a sensor on the back side of the block, below the oil filter which is two prong coming off of the block
my harness in my del sol does not have the plug to go on this..but it was on the harness i got with the motor for an ef
anyone know what this is?
can i just wire that plug into my existing del sol harness?
p.s....ive heard it could be a knock sensor..but i dk
Old 12-17-2008, 08:12 PM
jdmsinglecamdelsol's Avatar
pretty sure it the knock sensor i have the same setup run a p28 ecu and you wont have to wire the knock sensor up...you will have to run vtec wires if not alread done so
tjdmcoupe
04-22-2012 07:27 PM
shesinmyroom
06-21-2011 02:23 PM
17
08-05-2006 11:54 AM
CRXSiR71777
03-12-2002 06:04 PM
Quick Reply: obd1 sensor HELP
