obd1-obd2 conversion harness
obd1-obd2 dizzy conversion harness problems
hey i cant seem to find an accurate obd1-obd2 conversion harness that works.. can anyone help me out?
Modified by Jbur074 at 11:35 AM 9/29/2007
Re: obd1-obd2 conversion harness (Jbur074)
i used to have a JDM b18 in the car with that dizzy harness, but that wouldnt start the USDM b18 i droped in today. so i tried a diffrent way and it didnt work either..
is the JDM and USDM dizzy wiring harness the same?
the engine turns over but receives no spark. the firing order is right, the spark plugs are good. im totally lost in this harness
just splice the wires together, same color for color. or to make it simpler MSD makes an adapter wire harness, costs about $30. just order it through your local retailer. kragen or autozone.
Re: obd1-obd2 conversion harness (99accordf23a)
check the wires running to your distributor sometimes there may be a loose wire, we had your same problem on a 90 integra adn it took us forever to figure it out just make sure all the connectors r plugged into the distributor plug
billmongold
01-17-2020 06:50 PM
CRX91SE
03-31-2011 10:29 PM
alexb16hb
04-16-2007 10:32 AM
invisible
11-19-2006 09:23 AM
