OBD1 ecu for LS swap?
i recently put in a 97 b18b into my 00 hatch.. im running with the CEL because of my testpipe.. car hesitates sometimes..
id like to switch to obd1 sometime in the near future to fix this problem..
which ecu should i run?
i always see ppl talking about p28 but isnt that more for vtec applications? what are my other options?
thanks.
thanks.
Re: OBD1 ecu for LS swap? (superboy)
Run a LS ECU or you can also run a DX ECU but better to run the LS ECU. If you run a P28 or any other VTEC computer, the computer is going to look for VTEC and will throw you a VTEC code when it doesn't see any sensors hooked up to the computer.
Re: OBD1 ecu for LS swap? (Newman)
chipped OBD1 P75, this is the LS ecu.
chipped OBD1 p06, non-vtec civic ecu.
You'll need a X-over harness.
PM me if you need any of this stuff.
-PHiZ
-PHiZ
ceLtic*
04-14-2005 01:39 PM
