OBD1 DOHC ZC swap into 95 civic coupe clutch question.
Ok my question is for what year should i get a clutch for???,,this is a obd 0 ZC being converted obd 1. The clutch i took off the ZC tranny slides right onto my 95 tranny the motor in the 95 is a d15b7. There is a slight difference in size the,the 95 clutch is a little bit bigger. I figure i could use 95 clutch but i want to cover all my bases before i order a $300 SPEC clutch, thanks jt
Former Moderator
Re: OBD1 DOHC ZC swap into 95 civic coupe clutch question. (jtmoney2002)
Yes get the 92-95 Civic clutch.
You are planning on using a 92-95 Civic tranny, right?
Re: OBD1 DOHC ZC swap into 95 civic coupe clutch question. (B18C5-EH2)
yeah ill be useing the 95 tranny left it in the car when i pulled the motor figured it would be easier when i drop it back in
B18cHatch4u
09-16-2005 03:16 PM
GeorgeLouis1618
10-15-2004 10:42 AM
