obd 1 and 2 questions?!!!
Old 11-15-2007, 12:04 PM
pmpm06's Avatar
Default obd 1 and 2 questions?!!!
so i have a 96 hatch.....with an obd II ls swap in it.....the motor is knocking and i found a replacement....however, it's a 95 obd I motor.....so in order for me to just drop this obd I motor in the car, i have to do what to make it work??
Modified by pmpm06 at 1:34 PM 11/25/2007
Old 11-15-2007, 12:15 PM
sleeperrex's Avatar
Default Re: obd 1 and 2 questions?!!! (pmpm06)
obd1 wire harness, or if u have the obdII ls still swap obdII equipment over so itll plug straight up.
Old 11-25-2007, 10:37 AM
pmpm06's Avatar
swap what obd II equipment? someone told me all i would have to do is change oil pumps and the lower crank gear and use my obd II injectors....??
Old 11-25-2007, 04:48 PM
pmpm06's Avatar
can someone please let me know
Old 11-25-2007, 09:17 PM
USDMCIVICHATCH's Avatar
Default Re: (pmpm06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pmpm06 &raquo;</TD></TR><TR><TD CLASS="quote">swap what obd II equipment? someone told me all i would have to do is change oil pumps and the lower crank gear and use my obd II injectors....??</TD></TR></TABLE>
you just answered it for yourself unless you are already using an 0bd1 ecu with a jumper harness then you won't have to do any of that, and for the person who said use an obd1 harness don't post crap unless you know what you are talking about
pmpm06
12-28-2007 07:29 PM
orientalgunz_00
03-15-2006 10:55 PM
gsr9ek6
10-27-2005 07:59 PM
turbo*s2k
12-24-2003 08:17 AM
Quick Reply: obd 1 and 2 questions?!!!
