o2 simulator ??
o2 simulator ??
i have a b16 in my civic with a stock exhaust manifold, with no cat with test pipe! will the o2 simulator work to pass emissions! http://cgi.ebay.com/ebaymotors...ZWD1V or should just goto the muffler shop and get an oem CATALYTIC CONVERTER installed!
the o2 simulator will only tell the computer that the cat is working. if they put a sniffer in your pipe, you will fail.
an o2 simulator will do nothing for emissions. just put a high flow cat on. jackson racing did a dyno and proved that their highflow cat caused the car to loose 1 hp versus open header.
Re: (gftgrill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gftgrill »</TD></TR><TR><TD CLASS="quote">the o2 simulator will only tell the computer that the cat is working. if they put a sniffer in your pipe, you will fail.
an o2 simulator will do nothing for emissions. just put a high flow cat on. jackson racing did a dyno and proved that their highflow cat caused the car to loose 1 hp versus open header.</TD></TR></TABLE>
WA state emissions, 96 plus cars with obdII(is what i have) they do a gas cap check and plug-in to check the ECU for any check engine false, so will the o2 simulator work for this situation? $250 will cost me for labor for a stock converter!
it should work in that case.
just get a carsound/magnaflow high flow cat.
I got mine for about 140 shipped through hottexhaust.com
or you can get a jackson racing one for about 200
and if you install it yourself, labor is free. it can be done in less than an hour
Re: (gftgrill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gftgrill »</TD></TR><TR><TD CLASS="quote">an o2 simulator will do nothing for emissions. .</TD></TR></TABLE>
glad im in texas
glad im in texas
Re: (dewoine)
if its obd1, don't even try an o2 sim, it'll be a waste of time and dangerous for the motor. They are designed for the secondary o2 on obd2 cars, and even then they don't always work. Get a cat for emissions.
EM1SiR
11-12-2003 10:03 AM
