Noise coming from tranny???
well i was hearing a wierd noise and couldnt locate it but when i press the clutch the noise goes away, what could be the problem??
input shaft bearing. its inside the actual transmision. not in the bell housing. u have to take the tranny off seperately from thebell housing and its the bearing against the tranny where your input shaft comes through. NOT YOUR Throwout Bearing!!. i have the same problem.
Re: (TurboSI24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSI24 »</TD></TR><TR><TD CLASS="quote">what caused that to happen, was it the new clutch i installed??</TD></TR></TABLE>
You probably forgot to install the Pilot bearing. the bearing that goes into your block. its located at the end of the input shaft. you mah have forgotten to put that in and put more load on your input shaft. happened to me a year ago.
jmm96gsr
Transmission & Drivetrain
27
06-25-2009 06:30 PM
HomicidalHatchBack
10
11-11-2006 05:47 PM
