no spark need some help
someone help, im not getting spark. mini me converted to obd1 using p28. wiring is all correct. replaced the ignition coil and ignitor 4 times with good ones. spark plugs wires are good. when i take the dizzy out and put it back in and crank, it will start but die quickly, then after that, no spark. anyone have any ideas????
i tested my coil and im getting zero resistance between the + and - terminals, the manual says it should have .6-.8. how do i know if my coil or igniter is bad?!?!?!
also this is on a crx but no one in the ef forum seems to have any idea.
Re: no spark need some help (TeamNextGenChris)
thats the thing i dont understand, i replaced the coil with 4 different ones, and two came off of a good dizzy that i had spark with only a day before. in the manual it says the resistance needs to be between .6-.8, on the ones i have i get zero resistance (maybe im using my meter wrong), so then i checked the dizzy thats in my car right now (my daily driver) and i get zero resistance on that one too (that car runs tho), so i dont know ???
Re: no spark need some help (menappi)
honda is known for bad dizzys, because they have to many electronics in a small space creates a static or something like that will blow components in the distributor.. try to replace it..
d
e
x
d
e
x
