No power to anywhere on eg???
So I bought an eg shell with no motor. I threw in a d16z6. So far I have all the plugs hook up but for some reason I have no power at all. The harness and ecu I'm using came off another hatch that had an alarm install. I don't know if the ignition kill from the alarm or maybe ecu is preventing power distribution. I tried on two different harness but they both had alarm hooked to them before. So, basically there is no power at all. Batterry is good btw. Radiator is not on but i think there should be power without. Anything will be helpful. Thanks in advance!
Re: No power to anywhere on eg???
did you connect your chassis grounds? i bet you thats your issue. your circuit is not complete. do a search on here and youll find the locations for where they are at. i wanna think if i remember correctly their should be 3 grounds(dont quote me until you search though...lol)
adam jeffery
adam jeffery
adam jeffery
adam jeffery
So, all the ground must be connect to complete circuit?
And correct me if I'm wrong, there should be one from the valve cover to chasis too right?
BTW, the things I've tried already are switching/jumping battery. Replace both fuse boxes and even tried a different harness... so hopefully it's the ground wiring only.
Thanks...
yes their is one for sure from valve cover, and of course the batt. a couple other locations as well. its late and my brain dont work.....
adam jeffery
adam jeffery
You have the grounding good, then check also the big 80amp fuse in the engine bay fuse box to see if that is bad, its for the battery itself.
B-SerioUs EGg
01-24-2006 09:48 AM
Redline it.
06-16-2005 11:39 PM
