No odometer or speedometer. HELP!!!!
I changed the gauges in my 2001 civic to just some white outs. When I changed them I unhooked the guages completly. Now I have everything hooked back up but my odometer and speedometer do not work. I have double and even triple checked everything to make sure I hooked everything back up and still no odometer or speedometer. Everything else works, tach, gas guage, cc, everything.
Is there something I have to reset? Any ideas?
Any help or suggestions would be appreciated.
Re: No odometer or speedometer. HELP!!!! (2001blackcivic)
Speedometer cable. If the 2001's have one that is. It is a cable that has a square drive pin inside the connector. Push it into the back of the cluster and twist to lock it down.
mine dont work as well....i did a d16y8 swap into my eg cuz i needed to replace it for cheap just to get around..everything else works except my speedometer and odometer...i did not play around with the guages or anything..just did a regular swap...need help..
remstarasianboy
10-25-2005 10:15 AM
