no gas to motor need help asap
i just finished doing a b18b1 swap on my 98 lx 4d. first of all its a 98 ls block with crower turbo rods and srp 10.5 : 1 81.5 mm high compression with a 97 ls head with crower stage 2 all race cams. before i tried to started the motor i gave it a good couple of turns to check it if everything was alright it turned fine. the motor when i tried to start it wanted to turn over but it would just crank it sounded like it was going to turn over but it just would not go over. could it be my timeing of my cam i set them at piston 1 at TDC and both cam gears were pointing up. in between me trying to start it i got couple of misfires. so i decided to pull out the spark plug and there was no trace of gas going to the pistons. i do hear the gas pump and i can feel the gas going throught the gas line to the fuel rail could it be mine injectors they are a year or so old? i am using my 98 lx obd2a wiring harness and using a jumper harness to convert it to obd1 do i need to do any special wiring to the injectors? i had just finished doing a valve lash adjustment? but in the end there still no gas to the motor meaning no fire has any one done a ls swap using a lx harness please help! any and all comments and suggestions are welcome!!!
curioso
10
10-18-2010 06:55 AM
